Ardumower Sunray
Version vom 27. Juni 2020, 10:27 Uhr von Alexanderg (Diskussion | Beiträge) (→‎WiFi module (optional))
  • Optimized for Arduino Due
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
Tip: You can use Google Maps to find out (Lon, Lat) coordinates for your location: https://www.latlong.net/ PCB
Longer battery operation time
Optionally, you can add a ESP8266-01 WiFi module (found in the shop) to your PCB1.3 and use it with the Sunray firmware:
If you experience connection issues, you may have to add an additional capacitor (e.g. 470 uF/10V) to the module as shown in the photo.
Look into firmware file 'config.h' on how to configure SSID and (a static) IP. Also, look into the serial console (Download section, step 7) if you experience connection issues.
500px
500px
How the path finding works
600px
600px 400px
How the line tracking works
  1. the lateral error (distance from the planned (green) line - see yellow arrows below)
  2. the angular error (angle to the goal/target - see red arrows below)
600px
600px
MSG (messages):
  F5-05 RTCM3.3 1005
  F5-4A RTCM3.3 1074
  F5-54 RTCM3.3 1084
  F5-5E RTCM3.3 1094
  F5-7C RTCM3.3 1124
  F5-E6 RTCM3.3 1230
MSG (messages)
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
