Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 15 Odometry test
- 17 RTK float-to-fix recovery and false-fix issues
- 21 IMU, sensor fusion
- 24 WiFi module
- 25 How the waypoints are generated
- 26 How the path finding works
- 27 How the obstacle avoidance works
- 28 How the line tracking works
- 29 What data is transferred to the Arduino
- Optimized for Arduino Due
- the lateral error (distance from the planned (green) line - see yellow arrows below)
- the angular error (angle to the goal/target - see red arrows below)
MSG (messages)
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
