Ardumower Sunray
Version vom 5. Juli 2020, 09:16 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Bluetooth Low Energy (BLE) and WiFi external antenna hacks)
  • Optimized for Arduino Due
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
Longer battery operation time
500px
500px
How the path finding works
Click here for path finder demonstration video
600px
600px 400px
How the line tracking works
  1. the lateral error (distance from the planned (green) line - see yellow arrows below)
  2. the angular error (angle to the goal/target - see red arrows below)
600px
600px
MSG (messages):
  F5-05 RTCM3.3 1005
  F5-4A RTCM3.3 1074
  F5-54 RTCM3.3 1084
  F5-5E RTCM3.3 1094
  F5-7C RTCM3.3 1124
  F5-E6 RTCM3.3 1230
MSG (messages)
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
