Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Position source mode
- 17 Odometry test
- 20 XBee RF bandwidth/corruption issues
- 21 GPS antenna selection guide
- 22 IMU, sensor fusion
- 23 Extending WiFi range with outdoor access point
- 24 Portable WiFi router for NTRIP
- 25 Longer battery operation time
- 26 WiFi module
- 27 Bluetooth Low Energy (BLE) and WiFi external antenna hacks
- 28 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 29 Discussion / questions / forum thread
- Optimized for Arduino Due
MSG (messages)
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
