Ardumower Sunray
Version vom 27. Juli 2020, 08:06 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Discussion / questions / forum thread)
  • Optimized for Arduino Due
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
If you experience ublox GPS receiver transmission checksum errors (shown in the Arduino serial monitor or in the App under Statistics)...
Longer battery operation time
MSG (messages):
  F5-05 RTCM3.3 1005
  F5-4A RTCM3.3 1074
  F5-54 RTCM3.3 1084
  F5-5E RTCM3.3 1094
  F5-7C RTCM3.3 1124
  F5-E6 RTCM3.3 1230
MSG (messages)
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
IMU-Sensor: https://forum.ardumower.de/threads/imu-tilt-error-9250.23864/
GPS/RTK WiFi NTRIP: https://forum.ardumower.de/threads/frage-zum-gps-rtk-wifi-ntrip.23866/post-41712
XBee Long Range module, up to 14km, 13 dBm ERP (Xbee SX 868 xb8x-dmrs-001)
