Ardumower Sunray
Version vom 29. Juli 2020, 20:30 Uhr von Alexanderg (Diskussion | Beiträge) (→‎What are the differences between the Ardumower and ArduSimple ublox receiver configurations)
  • Optimized for Arduino Due
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
If you experience ublox GPS receiver transmission checksum errors (shown in the Arduino serial monitor or in the App under Statistics)...
Longer battery operation time
There are now two variants of the Ardumower battery pack (5Ah and 10Ah): https://www.asn-shop.de/Ardumower-Rasen-Roboter-Akku
MSG (messages)                   transmit frequency (10 means message is sent every 10 solutions):
  F5-05 RTCM3.3 1005             1
  F5-4A RTCM3.3 1074             1
  F5-54 RTCM3.3 1084             1
  F5-5E RTCM3.3 1094             1
  F5-7C RTCM3.3 1124             1
  F5-E6 RTCM3.3 1230             1
  F0-00 NMEA-GxGGA               10
  01-07 UBX-NAV-PVT              10
  01-12 UBX-NAV-VELNED           1
  01-14 UBX-NAV-HPPOSLLH         1
  01-3C NAV-RELPOSNED            1
  02-32 RXM-RTCM                 1
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
XBee Long Range module, up to 14km, 13 dBm ERP (Xbee SX 868 xb8x-dmrs-001)
