Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Position source mode
- 17 Odometry test
- 20 GPS checksum errors
- 23 IMU, sensor fusion
- 27 Docking
- 28 WiFi module
- 32 Troubleshooting
- 33 Datasheets
- Optimized for Arduino Due
If you experience ublox GPS receiver-to-Arduino transmission checksum errors (shown in the Arduino serial monitor or in the App under Statistics->GPS checksum errors)...
There are now two variants of the Ardumower battery pack (5Ah and 10Ah): https://www.asn-shop.de/Ardumower-Rasen-Roboter-Akku
PRT (ports) UART2, protocol in: RTCM3, protocol out: RTCM3, 115200 baud RATE (rates) measurement period: 1000ms (1 Hz) TMOD3 (Time mode3) mode: Fixed mode MSG (messages) transmit frequency (10 means message is sent every 10 solutions): F5-05 RTCM3.3 1005 1 F5-4A RTCM3.3 1074 1 F5-54 RTCM3.3 1084 1 F5-5E RTCM3.3 1094 1 F5-7C RTCM3.3 1124 1 F5-E6 RTCM3.3 1230 1
F0-00 NMEA-GxGGA 10
01-07 UBX-NAV-PVT 10
01-12 UBX-NAV-VELNED 1
01-14 UBX-NAV-HPPOSLLH 1
01-3C NAV-RELPOSNED 1
02-32 RXM-RTCM 1
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
XBee Long Range module, up to 14km, 13 dBm ERP (Xbee SX 868 xb8x-dmrs-001)
