Ardumower Sunray
Version vom 30. Juli 2020, 12:08 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Longer battery operation time)
  • Optimized for Arduino Due
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
If you experience ublox GPS receiver-to-Arduino transmission checksum errors (shown in the Arduino serial monitor or in the App under Statistics->GPS checksum errors)...
Arduino serial monitor:
MSG (messages)                   transmit frequency (10 means message is sent every 10 solutions):
  F5-05 RTCM3.3 1005             1
  F5-4A RTCM3.3 1074             1
  F5-54 RTCM3.3 1084             1
  F5-5E RTCM3.3 1094             1
  F5-7C RTCM3.3 1124             1
  F5-E6 RTCM3.3 1230             1
  F0-00 NMEA-GxGGA               10
  01-07 UBX-NAV-PVT              10
  01-12 UBX-NAV-VELNED           1
  01-14 UBX-NAV-HPPOSLLH         1
  01-3C NAV-RELPOSNED            1
  02-32 RXM-RTCM                 1
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
  • Does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above on how to increase Arduino serial FIFO size.
  • Does the 'DGPS age' shown in the App increase too much (>5 seconds)? If yes, verify your WiFi or XBee connection (see section extending outdoor WiFi above on how to improve WiFi connection).
