Ardumower Sunray
Version vom 8. August 2020, 15:26 Uhr von Alexanderg (Diskussion | Beiträge) (→‎How can I find out if my NTRIP provider (e.g. SAPOS) properly works and supports the required correction messages)
  • Optimized for Arduino Due
9. Choose 'View->Configuration View'. Choose configuration message 'TMOD3(Time mode 3)' and choose Mode '2 - Fixed Mode'. Enter your base coordinates as shown in the image and click on 'Send'. Your base should get a '3D' position solution.
  3. Change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 2048
Longer battery operation time
  • Does the robot position jump sporadically and does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above (GPS checksum error) on how to increase Arduino serial FIFO size.
  • Does the 'DGPS age' shown in the App increase too much (>5 seconds)? If yes, verify your WiFi or XBee connection (see section extending outdoor WiFi above on how to improve WiFi connection). Also, verify the LEDs on the GPS modules - at the base, the LED 'GPS->XBEE' should blink and on the rover, the LED 'XBEE->GPS' should blink.
