Ardumower Sunray
Version vom 9. August 2020, 22:57 Uhr von Alexanderg (Diskussion | Beiträge) (→‎GPS antenna selection guide)
  • Optimized for Arduino Due
  3. Change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 2048
Longer battery operation time
  • Does the robot position jump sporadically and does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above (GPS checksum error) on how to increase Arduino serial FIFO size.
