Ardumower Sunray
  • Optimized for Arduino Due
Before connecting GPS, verify the odometry of your motors! If you are unable to manually steer the robot via the App, this will probably fix it!
Finally, the motors should be smoothly manually controllable as seen in this video: https://youtu.be/fHSolQ5oQfA?t=136
  3. Change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 2048
Longer battery operation time
  • Does the robot position jump sporadically and does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above (GPS checksum error) on how to increase Arduino serial FIFO size.
