Ardumower Sunray
Version vom 17. August 2020, 11:56 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Download, Arduino Code, Firmware)
  • Optimized for Arduino Due
6. Connect Arduino Due USB native port to your Computer's USB port. Upload the sketch to your Arduino Due on the Ardumower PCB1.3. After a short while you should hear a 'beep'. Ardumower is now ready for your commands!
  3. Change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 2048
Longer battery operation time
