Ardumower Sunray
Version vom 31. August 2020, 11:31 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Adafruit Grand Central M4)
If using the Adafruit Grand Central M4, you have to add 2.2K pullup resistors as shown below:
[File: Adafruit_grand_central_m4.png|400px]
6. Connect Arduino Due USB native port to your Computer's USB port. Upload the sketch to your Arduino Due on the Ardumower PCB1.3. After a short while you should hear a 'beep'. Ardumower is now ready for your commands!
Longer battery operation time
