Ardumower Sunray
Version vom 31. August 2020, 11:36 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Adafruit Grand Central M4)
If using the Adafruit Grand Central M4 (highly recommended) instead of Arduino Due, you have to add 2.2K resistors (aka 'I2C pull-up') as shown below:
6. Connect Arduino Due USB native port to your Computer's USB port. Upload the sketch to your Arduino Due on the Ardumower PCB1.3. After a short while you should hear a 'beep'. Ardumower is now ready for your commands!
Longer battery operation time
