Ardumower Sunray
Version vom 31. August 2020, 11:59 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Adafruit Grand Central M4)
  1. If using the Adafruit Grand Central M4 (highly recommended) instead of Arduino Due, you have to add 2.2K resistors (aka 'I2C pull-up') as shown below:
  1. Disable PCB1.3 jumper JP13 (deactivate Arduino Due clone reset circuit)
NOTE: It is recommended to upgrade the bootloader on the Adafruit Grand Central M4 board:
  1. Download the the latest bootloader file here (look for .UF2 bootloader file): https://circuitpython.org/board/grandcentral_m4_express/
  3. Copy the bootloader file to the Adafruit Grand Central M4 drive ('GCMBOOT') - the drive will disappear and after 10 seconds the drive will appear again. The bootloader upgrade has finished.
Alternative instructions here: https://learn.adafruit.com/adafruit-grand-central/update-the-uf2-bootloader
After upgrading the bootloader, follow the instructions here to add Adafruit Grand Central M4 support to the Arduino IDE: https://learn.adafruit.com/adafruit-grand-central/setup
6. Connect Arduino Due USB native port to your Computer's USB port. Upload the sketch to your Arduino Due on the Ardumower PCB1.3. After a short while you should hear a 'beep'. Ardumower is now ready for your commands!
Longer battery operation time
