Ardumower Sunray
Version vom 31. August 2020, 14:06 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Download, Arduino Code, Firmware)
If using the Adafruit Grand Central M4 (highly recommended) instead of Arduino Due...
  1. Add 2.2K resistors (aka 'I2C pull-up') to the Adafruit Grand Central M4 board as shown below.
  3. It is recommended to upgrade the bootloader on the Adafruit Grand Central M4 board. Download the the latest bootloader file here (look at the bottom of this link for .UF2 bootloader file): https://circuitpython.org/board/grandcentral_m4_express/
  7. Adding support for Adafruit Grand Central M4 to the Arduino IDE (so that the Grand Central M4 appears as board) is described further below (section 'Download, Arudino, Firmware').
4.2 For Adafruit Grand Central M4: Follow the instructions here to add Adafruit Grand Central M4 support to the Arduino IDE: https://learn.adafruit.com/adafruit-grand-central/setup
Longer battery operation time
