Ardumower Sunray
Version vom 2. September 2020, 20:23 Uhr von Alexanderg (Diskussion | Beiträge) (→‎What are the differences between the Ardumower and ArduSimple ublox receiver configurations)
  1. Add 2.2K resistors (aka 'I2C pull-up') to the Adafruit Grand Central M4 board as shown below.
  3. It is recommended to upgrade the bootloader on the Adafruit Grand Central M4 board. Download the the latest bootloader file here (look at the bottom of this link for .UF2 bootloader file): https://circuitpython.org/board/grandcentral_m4_express/
  7. Follow the instructions here to add 'Adafruit Grand Central M4' support to the Arduino IDE by installing both Arduino SAMD boards and Adafruit SAMD boards packages : https://learn.adafruit.com/adafruit-grand-central/setup
Longer battery operation time
  Min SV elevation                        10          OR    10 (hartmut config)      10 (default)
  C/N0 Threshold #SVs                     10          OR    0  (hartmut config)      0
  dbHz                                    30          OR    10 (hartmut config)      0
