Ardumower Sunray
Version vom 14. September 2020, 23:49 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Hardware debugging)
  3. It is highly recommended to upgrade the bootloader on the Adafruit Grand Central M4 board. Download the the latest bootloader file here (look at the bottom of this link for .UF2 bootloader file): https://circuitpython.org/board/grandcentral_m4_express/
  7. Follow the instructions here to add 'Adafruit Grand Central M4' support to the Arduino IDE by installing both Arduino SAMD boards and Adafruit SAMD boards packages : https://learn.adafruit.com/adafruit-grand-central/setup
Longer battery operation time
  Min SV elevation                        10          OR    10 (hartmut config)      10 (default)
  C/N0 Threshold #SVs                     10          OR    0  (hartmut config)      0
  dbHz                                    30          OR    10 (hartmut config)      0
  1. Insert a FAT32 formatted SD card into the Adafruit Grand Central M4
  3. Locate the compiled 'sunray.bin.elf' file and make a copy of it:
    1. In Arduino IDE, enable 'full output during compilation and upload' via menu File->Preferences
    2. Compile the sunray.ino file
    3. Look into the Arduino output
