Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 Adafruit Grand Central M4
- 10 RTK base
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 16 Position source mode
- 21 GPS checksum errors
- 24 IMU, sensor fusion
- 25 Ultrasonic sensor
- 29 Docking
- 30 WiFi module
- 33 Troubleshooting
- 34 How to record GPS data
- 35 Datasheets
- 36 Data privacy
- 38 SD card logging
- 39 Hardware debugging
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 10
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
Min SV elevation 10 OR 10 (hartmut config) 10 (default)
C/N0 Threshold #SVs 10 OR 0 (hartmut config) 0
dbHz 30 OR 10 (hartmut config) 0
3. Locate the compiled 'sunray.ino.elf' file and make a copy of it:
4. Run your robot. If some unexpected RESET appears, the Arduino will save additional 'stack dump' information in the log file that corresponds to the compiled binary (sunray.ino.elf).
Developers/users can inspect the stack dump (found in the log files at the top) as follows:
2. To list the code for an address from the stack dump, use the GDB list command - Example:
