Ardumower Sunray
Version vom 17. September 2020, 10:39 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Rover configuration (messages))
  3. It is highly recommended to upgrade the bootloader on the Adafruit Grand Central M4 board. Download the the latest bootloader file here (look at the bottom of this link for .UF2 bootloader file): https://circuitpython.org/board/grandcentral_m4_express/
  7. Follow the instructions here to add 'Adafruit Grand Central M4' support to the Arduino IDE by installing both Arduino SAMD boards and Adafruit SAMD boards packages : https://learn.adafruit.com/adafruit-grand-central/setup
NOTE: below steps for rover configuration using u-center are no longer necessary - the Sunray firmware will automatically configure your ublox f9p GPS module (rover) when started - you can skip this section
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
