Ardumower Sunray
Version vom 24. September 2020, 09:27 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Adafruit Grand Central M4)
5. Remove any JP12 (GPS signal) jumpers (please ignore the photo for this jumper - we will not use the level shifter, see section GPS pin fix further below)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
