Ardumower Sunray
Version vom 29. September 2020, 13:57 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Portable WiFi router for NTRIP)
5. Remove any JP12 (GPS signal) jumpers (please ignore the photo for this jumper - we will not use the level shifter, see section GPS pin fix further below)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
P13_1  +5V              ----- R/C model VCC
P13_2  GND              ----- R/C model GND
P13_3  pinRemoteMow     ----- R/C model speed and direction channel (forward/backwards)
P13_4  pinRemoteSteer   ----- R/C model steering channel (left/right)
