Ardumower Sunray
Version vom 15. Oktober 2020, 10:07 Uhr von Alexanderg (Diskussion | Beiträge) (→‎XBee RF bandwidth/corruption issues)
  • Single mowing unit ground coverage performance (0.4m/s, 18cm path offset) : 100 qm per hour / 2400 qm (=0.24 hectare) per day
  • Overall power consumption (average) with single mowing unit: 30W (60W peak)
  • Single battery (125Wh) run-time (average): 4 hours / double-battery (250Wh): 8 hours
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
The below described GPS filter is now configured automatically in the Sunray firmware. Please skip this section.
The below described GPS message rates are now configured automatically in the Sunray firmware. Please skip this section.
Longer battery operation time
Automatic battery switch off
