AzuritBer Firmware (English)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
are set like that.
Odometry Setting
Value 1
200px
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
Value 2
Value 3
Mower need to rotate according your choice.
Motor Setting
Many Values are require and need to be set in correct order:
Value 1
Here you can adjust the RPM max speed and PWM max speed
First set the POWER MAX
PWM is use into automatic mode and need to be enought for the mower to reach the RPM max value.
If the wheel don't roll smoothly in manual forward ,you need to adjust the RPM_P RPM_I and RPM_D
Remember that at 80% of the power max the mower react like if a bumper is pressed.So to find the correct value ,simply deactivate bumper and In Manual / Forward stop the mower with your foot and normaly the mower stop before the wheel slip. State change to OFF and into console you can see the according message. Do not forget to reactivate the Bumper.
MotorSenseScaleLeft and right are here to help to have a real Power, but the main is that at 80% of Pawer max the mower stop and reverse.
