AzuritBer Firmware (English)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
Pi auto.png WIFI control using VNC Viewer from your sofa
Home assistant.png WIFI control using mqtt and compatible software (here Home Assistant [1])
It's level 2 but now:
First start Level 1
Setting
CONSOLE SHOW :
Set Force mowing off to YES
ODOMETRY Setting
Value 1
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
CONSOLE SHOW:
Value 2
Value 3
MOTOR Setting
See PID Control : [2]
MOW setting
Set the PWM Max speed to 255
Set the PWM Min speed to 150
STATION setting
PERIMETER setting
Mini Smag:
Timeout(s) if outside :
Big AREA Smag Center
Tracking Max Speed PWM
Circle Arc Distance...
Perimeter MAG MAX VALUE
Transition Timeout
Track Error Timeout
Track PID
Coil Polarity
Read the 2 coils
Block inner wheel
IMU setting
IMU Use
Compass Use
If your IMU is locate near electronics or motor ,It's better to deactivate the compass : The bylane mowing can result on drifting parallel lane without the compass but not always an issue in normal mowing condition.
Stop Mow Motor During Calib
P I D
Calibration Max Duration
Delay between 2 calib
'Drift Maxi in Deg per Second
Speed to find ComYaw
Without Compass
To check if it's OK:
Go To : Main Menu / Test IMU
With Compass
CONSOLE SHOW :
TIMER setting
BYLANE setting
BATTERY setting
Charge Factor
Battery Factor
Sense Factor
Go Home if Volt below
Switch off after minutes
Switch off if Volt below
Start charge if Voltage below
Stop charge if Sense below
SONAR setting
Sonar brake below
Sonar To Front Dist
RAIN TEMP setting
Rain Use
DHT22Use
Maximum Temperature
Level 2 Raspberry Pi
