Ardumower Sunray
Version vom 21. Januar 2021, 10:18 Uhr von Alexanderg (Diskussion | Beiträge) (→‎What is RTK and what are the requirements (environment and hardware))
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
Automatic battery switch off
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
Europe: XBee Long Range module, 868 MHz, up to 14km, 13 dBm ERP/20mW (Xbee SX 868 xb8x-dmrs-001)
North America: XBee XLR Range module, 915 MHz, up to 50 km (Xbee PRO SX MCQ-XBPSX)
Global: XBee Mid Range module, 2.4 Ghz, up to 300m (Xbee XB24CASIT-001)
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
