Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 Adafruit Grand Central M4
- 10 RTK base
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 16 Position source mode
- 21 GPS checksum errors
- 24 IMU, sensor fusion
- 25 Ultrasonic sensor
- 30 Docking
- 31 WiFi module
- 34 Troubleshooting
- 35 How to record GPS data
- 36 Datasheets
- 37 Data privacy
- 39 SD card module
- 40 SD card logging
- 41 R/C model
- 42 Hardware debugging
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA 60
- If you need to change the ESP8266 firmware use the following tool: https://www.espressif.com/en/support/download/other-tools (Flash Download Tools). Before starting the flashing procedure, GPIO_0 must be connected to Ground for the entire flashing procedure to enable programming mode. The pins can be found here : https://components101.com/wireless/esp8266-pinout-configuration-features-datasheet. The configuration of the download tool looks like this (ignore the firmware version used in the screenshots):
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
- South America: 433 MHz
- Africa: 433 MHz
- Asia: 415/433 MHz
- New Zealand: 917-927MHz
