Ardumower Sunray
Version vom 2. April 2021, 12:44 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Bluetooth Low Energy (BLE) and WiFi external antenna)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
volt=24
...some time later...
...many time later...
Automatic battery switch off
  2. If you need to change the ESP8266 firmware use the following tool: https://www.espressif.com/en/support/download/other-tools (Flash Download Tools). Before starting the flashing procedure, GPIO_0 must be connected to Ground for the entire flashing procedure to enable programming mode. The pins can be found here : https://components101.com/wireless/esp8266-pinout-configuration-features-datasheet. The configuration of the download tool looks like this (ignore the firmware version used in the screenshots):
You might use an ESP8266 (ESP-05) module like this and an external antenna from Marotronics (not tested by the Sunray author):
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
