Ardumower Sunray
Version vom 9. April 2021, 14:56 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Firmware Console Debugging)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
volt=24
...some time later...
...many time later...
Automatic battery switch off
Optionally, you can add a ESP8266-01 WiFi module (using ESP8266 NONOS SDK V2.2.1 firmware) found in the shop to your PCB1.3 and use it with the Sunray firmware. The App (client) will communicate directly with the mower (server, TCP port 80).
App (client) ==> Mower (server, TCP port 80)
Flashing WiFi module
For flashing the ESP, some user reported these settings to work better (no later connection errors with the ESP module):
boot_v1.2.bin --0x00000
user1.1024.new2.bin --0x01000
blank.bin --0x7e000
blank.bin --0x3fe000
esp_init_data_default.bin --0x3fc000
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
Console.png Here you can find out more details about boot process and how to find connection errors (e.g. Bluetooth/WiFi not connecting, GPS corruption errors etc.) using the serial console: https://docs.google.com/document/d/14qa15AKLG0EUfNJKfFPwAsKfrLlM0yoqJ1TyiM5c9Fk/edit?usp=sharing
