Ardumower Sunray
Version vom 11. April 2021, 12:25 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Bluetooth BLE UART module)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
volt=24
...some time later...
...many time later...
Automatic battery switch off
Optionally, you can add a ESP8266-01 WiFi module (using ESP8266 NONOS SDK V2.2.1 firmware) found in the shop to your PCB1.3 and use it with the Sunray firmware. The App (client) will communicate directly with the mower (server, TCP port 80).
App (client) ==> Mower (server, TCP port 80)
Flashing WiFi module
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
