Ardumower Sunray
Version vom 1. Mai 2021, 17:28 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Bluetooth BLE UART module)
4. Set JP7 (GpsV - GPS voltage) to 5V
5. IMPORTANT! Remove JP12 (GpsS - GPS signal level) jumpers (please IGNORE the photo for this jumper! - we will not use the level shifter, see section GPS pin fix further below)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
  2. Remove jumper Gps_S (JP12)
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
volt=24
...some time later...
...many time later...
Automatic battery switch off
Flashing WiFi module
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
