Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 Adafruit Grand Central M4
- 10 RTK base
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 16 Position source mode
- 21 GPS checksum errors
- 24 IMU, sensor fusion
- 25 Ultrasonic sensor
- 30 Docking
- 31 WiFi module
- 32 Bluetooth Low Energy (BLE) and WiFi external antenna
- 34 Troubleshooting
- 35 How to record GPS data
- 36 Datasheets
- 37 Data privacy
- 39 SD card module
- 40 SD card logging
- 41 R/C model
- 42 Hardware debugging
- 43 Firmware Console Debugging
- 44 Further links
1. Install ESP32 BLE+WiFi (recommended) or Bluetooth 4.0/BLE module (range 10m, 8 Kbps) on your Ardumower PCB1.3 (replace any installed Bluetooth 2.0 module).
4. Set JP7 (GpsV - GPS voltage) to 5V
5. IMPORTANT! Remove JP12 (GpsS - GPS signal level) jumpers (please IGNORE the photo for this jumper! - we will not use the level shifter, see section GPS pin fix further below)
- https://circuitdigest.com/microcontroller-projects/how-to-flash-the-firmware-on-cloned-hm-10-ble-module-using-arduino-uno
- https://www.obddiag.net/ble-adventures.html
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
- Remove jumper Gps_S (JP12)
F0-00 F0-00 NMEA GxGGA 60
Flashing WiFi module
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
- South America: 433 MHz
- Africa: 433 MHz
- Asia: 415/433 MHz
- New Zealand: 917-927MHz
