Ardumower Sunray
- 8 PCB1.3 GPS pin fix
- 9 PCB1.3 odometry divider
- 11 RTK base
- 12 RTK rover
- 15 Phone App
- 16 Odometry test
- 17 Position source mode
- 22 GPS checksum errors
- 25 IMU, sensor fusion
- 26 Ultrasonic sensor
- 27 Extending WiFi range with outdoor access point
- 28 Portable WiFi router for NTRIP
- 29 Longer battery operation time
- 30 Automatic battery switch off
- 31 Docking
- 32 WiFi module
- 33 Bluetooth Low Energy (BLE) and WiFi external antenna
- 34 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 35 Troubleshooting
- 36 How to record GPS data
- 37 Datasheets
- 38 Data privacy
- 39 Discussion / questions / forum thread
- 40 SD card module
- 41 SD card logging
- 42 R/C model
- 43 Hardware debugging
- 44 XBee modules configuration
- 45 Firmware Console Debugging
- 46 Further links
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
- Remove jumper Gps_S (JP12)
F0-00 F0-00 NMEA GxGGA 60
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
- South America: 433 MHz
- Africa: 433 MHz
- Asia: 415/433 MHz
- New Zealand: 917-927MHz
XBee modules configuration
- Start XCTU
Channel Mask: 3EFFFDFF Network ID: 1985 Broadcast Multi-Transmits: 3 RD Data Rate: 80 kps TX Power Level: 32 mW Unicast Retries: A Routing/Messaging Mode: Standard Router[0] Broadcast Hops: 0 Network Hops: 7 Mesh Unicast Retries: 1 Destination Address High: 0 Destination Address Low: FFFF Transmit Options: 40 Node Identifier: Network Discovery Back-off: 82 Network Discovery Options: 0 Cluster ID: 11 Encryption: Disabled [0] AES Encryption Key: Baud Rate: 115200 Parity: No Parity [0] Stop Bits: One stop bit [0] Packetization Timeout: 3 Flow Control Threshold: 11D API Enable: Transparent Mode [0] API Options: API Rx Indicator - 0x90 [0]
