Chassis 2021
Related pages:
- Ardumower Tutorials Chassis 2021 Teil 1 WasGehoertDazu
- Ardumower Tutorials Chassis 2021 Teil 2 Vorbereitung
- Ardumower Tutorials Chassis 2021 Teil 3 Montage
Tools
- Screw driver
- Different Torx screw driver
- Knife
- Round and flat file
- sand paper or sand sponge
Whats inside the Box?
Front-Plate
Mow-Plate
Wiring
Case assembly
Maintenance & Repair Tips
Clamping element will not tighten anymore
If your 'clamping' element will not tighten anymore (e.g. due to a smaller shaft diameter), add a heat shrink tubing as shown in the photo:
