Chassis 2021
Version vom 25. August 2021, 16:44 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Clamping element will not tighten anymore)
Related pages:
  1. Ardumower Tutorials Chassis 2021 Teil 1 WasGehoertDazu
  2. Ardumower Tutorials Chassis 2021 Teil 2 Vorbereitung
  3. Ardumower Tutorials Chassis 2021 Teil 3 Montage
Tools
  • Screw driver
  • Different Torx screw driver
  • Knife
  • Round and flat file
  • sand paper or sand sponge
Whats inside the Box?
Front-Plate
Mow-Plate
Wiring
Case assembly
Maintenance & Repair Tips
Clamping element will not tighten shaft anymore
If your 'clamping' element will not tighten anymore (e.g. due to a smaller shaft diameter), add a heat shrink tubing as shown in the photo:
instructions on ardumower forum
