Chassis 2021
Version vom 26. August 2021, 23:12 Uhr von Alexanderg (Diskussion | Beiträge) (→Clamping element will not tighten shaft anymore)
Related pages:
- Ardumower Tutorials Chassis 2021 Teil 1 WasGehoertDazu
- Ardumower Tutorials Chassis 2021 Teil 2 Vorbereitung
- Ardumower Tutorials Chassis 2021 Teil 3 Montage
Tools
- Screw driver
- Different Torx screw driver
- Knife
- Round and flat file
- sand paper or sand sponge
Whats inside the Box?
Front-Plate
Mow-Plate
Wiring
Case assembly
Maintenance & Repair Tips
If your 'clamping' element will not tighten shaft anymore (e.g. due to a smaller shaft diameter), you may:
- press the outer clamping element in a bench vise, OR
- (as a temporary solution) add a heat shrink tubing over the inner clamping element as shown in the photo (NOTE: this is a temporary solution and may not last forever as the heat shrink tubing may dissolve over time):
