Chassis 2021
Version vom 26. August 2021, 23:13 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Clamping element will not tighten shaft anymore)
Related pages:
  1. Ardumower Tutorials Chassis 2021 Teil 1 WasGehoertDazu
  2. Ardumower Tutorials Chassis 2021 Teil 2 Vorbereitung
  3. Ardumower Tutorials Chassis 2021 Teil 3 Montage
Tools
  • Screw driver
  • Different Torx screw driver
  • Knife
  • Round and flat file
  • sand paper or sand sponge
Whats inside the Box?
Front-Plate
Mow-Plate
Wiring
Case assembly
Maintenance & Repair Tips
If your 'clamping' element will not tighten shaft anymore (e.g. due to a smaller shaft diameter), you may:
  • press the outer clamping element in a bench vise (recommended)
  • OR, as a temporary solution, add a heat shrink tubing over the inner clamping element as shown in the photo (NOTE: this is a temporary solution and may not last forever as the heat shrink tubing may dissolve over time):
instructions on ardumower forum
