Chassis 2021
Version vom 27. August 2021, 10:40 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Clamping element will not tighten shaft anymore)
Related pages:
  1. Ardumower Tutorials Chassis 2021 Teil 1 WasGehoertDazu
  2. Ardumower Tutorials Chassis 2021 Teil 2 Vorbereitung
  3. Ardumower Tutorials Chassis 2021 Teil 3 Montage
Tools
  • Screw driver
  • Different Torx screw driver
  • Knife
  • Round and flat file
  • sand paper or sand sponge
Whats inside the Box?
Front-Plate
Mow-Plate
Wiring
Case assembly
Maintenance & Repair Tips
If your 'clamping' element will not tighten shaft anymore (e.g. due to a slightly reduced shaft diameter), you may:
  • press together the outer clamping element in a bench vise
  • OR use a filling under the 'ring'. Soda/beer can strip works fine for that. Wedged parts has slits, make sure those are not towards each other nor towards shaft d-slot.
  • OR add a heat shrink tubing over the inner clamping element as shown in the photo (NOTE: this is a temporary solution and may not last forever as the heat shrink tubing may dissolve over time):
instructions on ardumower forum
