Perimeter wire
Version vom 29. Dezember 2014, 12:31 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Sender diagnostics)
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
Principle:
Wave modulation
The sender signal always toggles between LOW and HIGH (LOW, HIGH, LOW, HIGH, LOW etc.). The next transmitted bit (logical 0 or 1) defines the width of the next pulse (=one half wave). So, let's call this modulation 'half-wave pulse-width modulation'.
Because the pulse width (one half wave) is modulated, the resulting frequency of the signal is in the range: 2404 Khz - 4808 Khz
Simulation
You can see how it works:
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Using a PC sound card to test the sender
Receiver
receiver circuit:
Receiver ADC calibration
Receiver diagnostics
sig:  coil signal (raw pulse sequence after ADC)
mag:  filter result: inside (negative) or outside (positive), magnitude: distance to perimeter wire (RSSI)
Additionally, you can connect the coil to an oscilloscope to to see the sender signal.
  1. Perimeter2 demo
  2. 120m perimeter wire test
