Ardumower PCB
Needed parts
- Main functions
- 1 x Arduino Mega 2560
- 1 x MC33926 motor driver module
- 1 x current sensor module ACS712-5
- Perimeter sender (optional)
- 1 x Arduino Nano
- 1 x Arduino Nano
- 1 x LM386 amplifier module
- Capacitor (1 x 4,7nF), 1 x Receiver coil 100mH
- Additional modules
Schematics
PDF for the SVN Version found here :http://www.ardumower.de/index.php/de/forum/dies-und-das/438-schaltplan-svn-version
KiCad Files are in the SVN
PCB assembly
- Single sided PCB "eurocard" dimensions 160x100mm (So you can build it yourself)
- All used modules are available in the ardumower shop
- Uses the arduino mega R3
- All connections are available on connectors as +5V and GND
You have two options:
- Download Download SVN developer code (recommended) OR
SVN version download steps:
Download and install Tortoise SVN client http://tortoisesvn.net/downloads.html
Choose 'URL of repository': https://ardumower.googlecode.com/svn/trunk/, and click OK
First-time calibration
Wheel motors
ADC calibration
Diagnostic
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
Config files
- config.h (old v9.0.3)
- mower.cpp (SVN version)
pfodApp
