Perimeter wire
Version vom 23. Januar 2015, 20:53 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Receiver diagnostics)
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
Principle:
Signal
The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
receiver circuit:
Receiver ADC calibration
sig:  coil signal (raw pulse sequence after ADC)
mag:  filter result: inside (negative) or outside (positive), magnitude: distance to perimeter wire (RSSI)
qty:  filter quality (how distinguisable inside and outside were in filter result)
Additionally, you can connect the coil to an oscilloscope to to see the sender signal.
  1. Perimeter2 demo
  2. 120m perimeter wire test
