Ardumower PCB
Needed parts
- Main functions
- 1 x Arduino Mega 2560
- 1 x MC33926 motor driver module
- 1 x current sensor module ACS712-5
- Perimeter sender (optional)
- 1 x Arduino Nano
- 1 x Arduino Nano
- 1 x LM386 amplifier module
- Capacitor (1 x 4,7nF), 1 x Receiver coil 100mH
- Additional modules
Schematics
Download PDF for the latest SVN version: https://ardumower.googlecode.com/svn/trunk/pcb/megashield_svn_0.5/ardumower%20mega%20shield%20svn.pdf
KiCad Files are in the SVN
PCB assembly
The PCB is made with the following design parameters:
- PCB dimensions 160x100 mm
- All used modules are available in the Ardumower shop
- Uses the Arduino Mega 2560 (and via adapter the Arduino Due)
PCB 1.0 prototype, jumpers
| LM350T charging control | D7: DIODE,
D4: DIODE |
D7: SHORT-CIRCUIT,
D4: SHORT-CIRCUIT |
Do not use if using external charger |
| External power while charging | JP6: CLOSE,
JP7: OPEN |
JP6: OPEN,
JP7: CLOSE |
Use for external power to your PCB (disconnect battery from PCB) while charging |
| Arduino controlled charge relay | JP4: CLOSE,
JP5: OPEN |
JP4: OPEN
JP5: CLOSE |
| Bluetooth VCC=3.3V | JP8: OPEN,
JP9: CLOSE |
JP8: CLOSE,
JP9: OPEN |
You have two options:
SVN version download steps:
First-time calibration
Wheel motors
ADC calibration
Diagnostic
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
Config files
- config.h (old v9.0.3)
- mower.cpp (SVN version)
pfodApp
