Ardumower PCB
Version vom 31. März 2015, 14:42 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Download and flash Arduino code)
Needed parts
  • Main functions
    • DC voltage step-down module
    • current sensor module
    • Resistors, Capacitors, Fuse
  • Perimeter sender (optional)
    • Arduino Nano
    • pre-amplifier module
    • Capacitor, Receiver coil
  • Additional modules
    • IMU module (gyro, accel. compass) (optional)
    • realtime clock module (optional)
    • Bluetooth module (for phone control)
Schematics/PCB files
Click here for latest version (PDF): https://github.com/Ardumower/ardumower/blob/master/pcb/megashield_svn_0.5/ardumower%20mega%20shield%20svn.pdf
The schematics and PCB files were created with KiCad. They can be downloaded from github and can be edited by open source KiCAD software.
  • PCB dimensions 241x114mm
  • Uses the Arduino Mega 2560
More photos to come...
PCB jumpers
Feature used YES NO Comment
Integrated LM350T charging control (recommended: NO) D7: DIODE
D3: DIODE
C1, C4, U4, RV1: used
D7: SHORT-CIRCUIT
D3: SHORT-CIRCUIT
C1, C4, U4, RV1: not used
JP7: OPEN
D4: DIODE
C5: not used
JP6: OPEN
JP7: CLOSE
D4: SHORT-CIRCUIT
C5: used
JP5: OPEN
JP4: OPEN
JP5: CLOSE
Bluetooth VCC=3.3V JP8: OPEN
JP9: CLOSE
JP8: CLOSE
JP9: OPEN
Many latest modules use 3.3V
PCB modules
PCB connectors
P4 reserved Yes
P6 Lawn sensor Yes
P7 Status LEDs Yes
P8 Odometry right Yes
P9 Odometry left Yes
P10 GPS (GY-NEO6MV2) Yes
P20 Button (Start/Stop) No
P21 Drop sensor right Yes
P22 Reserved Yes
P23 Reserved Yes
P24 Reserved Yes
P25 Reserved Yes
P26 Reserved Yes
P27 Reserved Yes
P28 Reserved Yes
P29 Reserved Yes
P30 Perimeter coil right Yes
P31 Drop sensor left Yes
P32 GND Yes
P33 5V Yes
P34 3.3V Yes
P35 Mower motor RPM Yes
P36 Reserved Yes
P37 Mower motor No
P38 Reserved Yes
P39 Reserved Yes
P40 User switches Yes
P41 Rain sensor Yes
P42 Charging pins Yes
P43 Battery (24V) No
P44 Wifi module (ESP8266) Yes
P45 Reserved Yes
P46 Reserved Yes
You have two options:
First-time calibration
Wheel motors
ADC calibration
Diagnostics/troubleshooting
  2. loop()-counts per second
  5. drive home? (1/0)
  11. "com" - compass course
  13. "bat" - Battery voltage
  14. "chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
Config files
  • config.h (old v9.0.3)
  • mower.cpp (SVN version)
pfodApp
