Perimeter wire
Version vom 15. Juni 2015, 21:24 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Receiver diagnostics/troubleshooting)
Magnetic field calculator
Principle:
Signal
  2. increase the signal length
We use a combination of both. The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
We use a motor driver as output amplifier and an Arduino Nano to generate the signal. The motor driver is driven by 3.2 Khz (two pulse widths 4808 Hz and 2404 Hz). With large enough perimeter wires, the circuit typically draws 20W (12V, 1.7A). We use a motor driver with integrated current limiting and thermal switch-off (e.g. MC33926). The perimeter wire length should be in the range 20m - 450m and must be at least 5 Ohm.
sender circuit:
 motor driver M1OUT1     o---------- perimeter loop (20-450 meters, > 5 Ohm) --+
               |---------o-- GND
               |---------o-- Arduino +5V
Sender perimeter lawn size
Sender current control
  • DC/DC Voltage: The motor driver supply voltage can be changed (6-12V via the potentiometer on the DC converter). That's one way to do it and it's the recommended way. NOTE: The minimum voltage (Vin) for the MC33926 motor driver is 6v. If the voltage is lower, the motor driver shuts down sporadically (undervoltage detection-Arduino LED starts to flash).
  • Normal amplitude: Instead of switching the perimter wire between +Vin and -Vin (double amplitude/default), the motor driver can switch it between +Vin and GND (normal amplitude). This will reduce current. To use normal amplitude, comment out the corresponding code line in 'sender.ino':
  • Power resistor: If your perimeter wire resistance (R) is below 5 Ohms, you will not be able to further reduce voltage below 6v (otherwise the motor driver will not work properly). Then you have to increase the perimeter wire resistance (R) by using a power resistor (example: 5 ohm, 10W) in series with your perimeter wire.
@6 volts (Vin): 5 ohm power resistor => I=U/R=6v/5ohm=1.2A   (P=U*I=6v*1.2A=7.2W)
MCP4151-5K version:
Vout = 1.23V*(1+VR1/R1)
Using VR1=5K...
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
receiver circuit:
* Coil to gear motor: > 15cm
* Coil to mower motor: > 10cm
Signal measurements
Coil and noise measurements
Receiver ADC calibration
  • Adjust voltage of sender: increase voltage (sender DC converter potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m) - For a short 20m wire (small R value), it is extremely difficult to set the correct DC voltage - if the voltage is too low, the motor driver shuts down sporadically (undervoltage detection-Arduino LED starts to flash), and if the voltage is too high, the motor driver shuts down sporadically (overcurrent detection--Arduino LED starts to flash).
Measurements
measurement:    AlexanderG_120m_loop
perimeter loop: length=120m
                R=7 ohm
                L=0.179 mH
sender:         Vpp(loop open)=24v    (DC=12V)
                Vpp(loop closed)=5v
receiver coil:  L=144 mH
                R=151 ohm
                Vpp(min)=20 mV
                Vpp(max)=150 mV
measurement:    AlexanderG_20m_loop
perimeter loop: length=20m
                R=2.5 ohm
                L=0.017 mH
sender:         Vpp(loop open)=10V     (DC=5V)
                Vpp=(loop closed)=8.6V
                R=151 ohm
                Vpp(min)=120 mV
                Vpp(max)=600 mV
note:           For a short 20m wire (small R value), it is extremely difficult to set the correct DC voltage -
                (overcurrent detection-Arduino LED starts to flash).
  1. Perimeter2 demo
  2. 120m perimeter wire test
  4. Sender PCB
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
l = coil length
D = coil diameter
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
