Perimeter wire
Version vom 22. Juni 2015, 14:33 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Sender current control)
Magnetic field calculator
Principle:
Signal
  2. increase the signal length
We use a combination of both. The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
 motor driver M1OUT1     o---------- perimeter loop (20-450 meters, > 5 Ohm) --+
 motor driver Vin        o-- 6.5V
               |---------o-- GND
               |---------o-- Arduino +5V
Sender perimeter lawn size
  • DC/DC Voltage: The motor driver supply voltage can be changed (6.5-12V via the potentiometer on the DC converter). That's one way to do it and it's the recommended way. NOTE: The minimum voltage (Vin) for the MC33926 motor driver is 5v. If the voltage is lower, the motor driver shuts down sporadically (undervoltage detection-Arduino LED starts to flash).
  • Normal amplitude: Instead of switching the perimter wire between +Vin and -Vin (double amplitude/default), the motor driver can switch it between +Vin and GND (normal amplitude). This will reduce current. To use normal amplitude, comment out the corresponding code line in 'sender.ino':
  • Power resistor: If your perimeter wire resistance (R) is below 5 Ohms, you will not be able to further reduce voltage below 6.5v (otherwise the Arduino will not work properly). Then you have to increase the perimeter wire resistance (R) by using a power resistor (example: 5 ohm, 10W) in series with your perimeter wire.
@6 volts (Vin): 5 ohm power resistor => I=U/R=6v/5ohm=1.2A   (P=U*I=6v*1.2A=7.2W)
MCP4151-5K version:
Vout = 1.23V*(1+VR1/R1)
Using VR1=5K...
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
receiver circuit:
* Coil to gear motor: > 15cm
* Coil to mower motor: > 10cm
Signal measurements
Coil and noise measurements
Receiver ADC calibration
  • Adjust voltage of sender: increase voltage (sender DC converter potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m)
Measurements
Noise MAX: smag=
Signal MIN: smag=
SNR=Signal/Noise=
2) 20m (0.7mm^2), R=2.5 Ohm, 6.5V, coil Vpp 120 mV
Noise MAX: smag=
Signal MIN: smag=
SNR=Signal/Noise=
  1. Perimeter2 demo
  2. 120m perimeter wire test
  4. Sender PCB
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
l = coil length
D = coil diameter
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
