Perimeter wire
Principle:
Signal
- increase the signal length
Filter
sender circuit:
motor driver M1OUT1 o---------- perimeter loop (20-450 meters, > 5 Ohm) --+
motor driver Vin o-- 6.5V
|---------o-- GND
|---------o-- Arduino +5V
Sender perimeter lawn size
area = PI * (r*r) = PI * (18m * 18m) = 1000 m2
Sender current control
- Power resistor: If your perimeter wire resistance (R) is below 5 Ohms, you will not be able to further reduce voltage below 6.5v (otherwise the Arduino will not work properly). Then you have to increase the perimeter wire resistance (R) by using a power resistor (example: 5 ohm, 10W) in series with your perimeter wire.
MCP4151-5K version:
Vout = 1.23V*(1+VR1/R1)
Sender automatic standby
Sender software
Sender diagnostics
Receiver
receiver circuit:
Signal measurements
Coil and noise measurements
Receiver ADC calibration
- Adjust voltage of sender: increase voltage (sender DC converter potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m)
Broken perimeter wire
- Increase your sender output voltage to 28 Volts
- Connect the LM386 amplifier signal output (signal and GND) to your PC's microphone input
- Launch the web oscilloscope, and switch into frequency view (choose visualization 'frequency spectrum')
- Now start at the side of the perimeter wire (the side that is still connected to the perimeter wire), and walk along the perimeter wire - the peak frequency of 3.2 Khz should always be there
- At the location where the wire is broken, the 3.2 Khz frequency is gone!
Measurements
Noise (max): smag=192 Signal (min): smag=254 SNR=Signal/Noise=254/192=1.3
Noise (max): smag=192 Signal (min): smag=896 SNR=Signal/Noise=896/192=4.6
- Perimeter2 demo
- 120m perimeter wire test
- Sender PCB
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
