PCB 1.2 (English)
Required parts for the Ardumower
What is needed for building your Ardumower:
- The Ardumower chassis including motors
- Important modules to choose:
- Accessories Set (resistors, pin strips etc.)
- 2 x Motor driver protection PCB
- 1 x Mega Board 2560 R3
- 1 x INA169 Current Sensor Board
- 2 x Dual motor driver MC33926
- 2 x DC-DC LM2596 Step-Down Converter
- 1 x Wireless Bluetooth module HC-05
- 1 x Real Time Clock I2C DS1307
- 1 x 24 Volt Charger for the Ardumower LithiumIon Battery
- Optional modules:
- 1 x Ardumower Power Pack
- 1 x 3 mowing blades + 3 screws, e.g. suitable for Automower® from Husqvarna®
Needed modules
- PCB dimensions 241x114mm
- Uses the Arduino Mega 2560
PCB building manual
- Schematics
- Photos
- Build instructions
- WorkaRound20150527
- WorkaRound20150530
PCB building videos
- Resistors
- Diodes and relay
- Capacitors and transistors
- Piezo buzzer and fuse
- Strip pins
- DC/DC converter
- RTC module
- Dual MC33926
- INA169
- Battery & charger
PCB jumpers
D7: DIODE
D7: SHORT-CIRCUIT
JP6: OPEN
JP5: OPEN |
JP4: OPEN
JP5: CLOSE |
JP9: CLOSE |
JP8: CLOSE
JP9: OPEN |
PCB modules
PCB connectors
| P4 | reserved | Yes | ||
| P6 | Lawn sensor | Yes | ||
| P7 | Status LEDs | Yes | ||
| P22 | Reserved | Yes | ||
| P23 | Reserved | Yes | ||
| P24 | Reserved | Yes | ||
| P25 | Reserved | Yes | ||
| P26 | Reserved | Yes | ||
| P27 | Reserved | Yes | ||
| P28 | Reserved | Yes | ||
| P29 | Reserved | Yes | ||
| P32 | GND | Yes | ||
| P33 | 5V | Yes | ||
| P34 | 3.3V | Yes | ||
| P36 | Reserved | Yes | ||
| P37 | Mower motor | No | ||
| P38 | Reserved | Yes | ||
| P39 | Reserved | Yes | ||
| P45 | Reserved | Yes | ||
| P46 | Reserved | Yes |
Motors
Voltages
Protector PCB
Wheel motors wiring
- steer the robot left/right
Wheel motor features:
- 24V (load current ~1A)
Motor wiring (left motor):
Wheel motors odometry wiring
Mower motor wiring
Motor decrease noise
Motor controller (PID)
Bluetooth module
Bluetooth HC-05
Charger
Total power balance
Battery
Charging station
Ultrasonic Sensor
An ultrasonic sensor (HC-SR04) allows Ardumower to detect obstacles.
Distance 2 to 450 cm
Wiring
Ultrasonic Module VCC (+5V) — PCB VCC (+5V) Ultrasonic Module GND — PCB GND Ultrasonic Module Trigger — PCB Digital Pin Ultrasonic Module Echo — PCB Digital Pin
An internal schematics of the sensor can be found here.[1]
Rain sensor
Using a rain sensor, your Ardumower can stop mowing when it starts to rain. Additionally, it can drive into your charging station.
NOTE: If using YL-83 module, we have no long-term experience regarding corrosion!
Wiring
GND o-----o GND Rain sensor module
+5V o-----o VCC Rain sensor module
Ardumower pinRain o-----o D0 Rain sensor module
Rain sensor module IN o----- rain sensor
Photos
GPS
Currently, GPS is used
GPS VCC -- PCB VCC GPS GND -- PCB GND GPS TX -- PCB GPS RX GPS RX -- PCB GPS TX
Model R/C
The Ardumower can be controlled via a model R/C. For remote controlling your robot mower you'll need:
- a model remote control (e.g. 2.4 Ghz)
- a suitable model remote receiver (4 channels or more)
Wiring
The channel assignment is:
left stick (left/right): pinRemoteSwitch left stick (up/down): pinRemoteMow right stick (left/right): pinRemoteSteer right stick (up/down): pinRemoteSpeed
WIFI
A WIFI module can be used as an alternative for Bluetooth communication. Again, pfodApp is required to connect WIFI and the phone.
https://github.com/FredericG-BE/ardumower/wiki/Using-ESP8266-WIFI-module-on-Ardumower
Realtime clock (RTC)
The robot requires a clock, so that it can start mowing automatically at certain time intervals (timer).
A realtime clock (RTC) returns current time (minute, hour) and date (day of week, day, month, year) - by the help of a battery (Lithium Ion LIR2032, 3.6v, 48 mAh) the time continues to run even if the robot mower is switched off.
Additionally, the RTC module contains an EEPROM memory (non volatile memory) that can hold 4K of permanent user data.
DS1307 module
Troubleshooting "Tiny RTC I2C module"
If your module is losing time/date, fix the circuit like this:
- Remove D1, R6 and R4
- Solder jumper wire in place of R6
- Inspect crystal soldering - fix if necessary
- Replace battery
Wiring
The RTC module is connected on the I2C bus of the Arduino Mega (in parallel with any other I2C modules).
DS1307 Module SDA — Arduino SDA Pin DS1307 Module SCL — Arduino SCL Pin DS1307 Module VCC (+5V) — Arduino VCC (+5V) DS1307 Module GND — Arduino GND
Note
If you experience communication problems when using multiple I2C modules on one I2C bus, it is recommended to reduce the length of the cables.
