Ardumower Sunray
Video.png Click below to watch demo and tutorial videos:
PCB     PCB
  • Optimized for Arduino Due
3. Connect GPS multifrequency patch antenna. NOTE: antenna cable is very sensitive, never bend the antenna cable!
PCB     PCB
XBEE>GPS should be OFF - your base module should not receive any XBee signal
600px
