Ardumower Sunray
Video.png Click below to watch demo and tutorial videos:
PCB     PCB
  • Optimized for Arduino Due
RTK external base service
This section describes how to use an external Internet-based correction service (NTRIP) instead of your own base station. You will require the WiFi NTRIP Master module for your rover PCB from Marotronics. Follow these steps for the rover PCB:
1. Instead of the XBee module install the WiFi NTRIP Master module on your rover PCB.
4. Configure your preferred NTRIP service provider, and through which WiFi network should it connect to internet.
5. Save configuration and reset the system. From now on, every time the WiFi hotspot you configured is in range, ArduSimple’s WiFi NTRIP Master will connect autonomously and provide RTK corrections to simpleRTK2B.
6. Connect the rover PCB via USB to your PC, and make sure NMEA GGA message is active on UART2 at 115'200bps. Some NTRIP service providers need this NMEA message to compute a virtal base station based on the estimate fix position.
PCB     PCB
NOTE: If you purchased your RTK-GPS modules at Marotronics, these modules should be pre-configured and you can skip this section. You can download the ublox F9P config files (with the changes below) here: https://github.com/Ardumower/Sunray.
age The age (in seconds) of the DGPS correction data (sent via the XBee module)
XBEE>GPS should be OFF - your base module should not receive any XBee signal
600px
