Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 16 XBee RF modules issues
- 17 Discussion / questions / forum thread
- 18 How the waypoints are generated
- Optimized for Arduino Due
You can change the message rates at the base via the configuration of the CFG-MSG message, choosing the above RTCM3 message and setting a non-zero rate value. For example setting the rate to 1 means every second, 2 means every two seconds etc. Do not forget to send and save the base configuration.
